Runing channels at different omhs.
93dakota
Ok so I have delt a good bit with mono block amps but not much with 4 channel amps so I dont want to F$%( any Thing up. I am Starting to plan my first wall build and I figure I will go all out and put some mids and highs in the wall as well. I was thinking of running 6 speakers in total. My question is, is it bad to wire two channels at 2 ohms and 2 channels at 2 ohms. I think it would be OK but just want to ask. The amp is a Hifonics Zeus Zxi 6410.
ZXI 6410
A/B Class
4 x 85 W @ 4 Ω
4 x 170 W @ 2 Ω
2 x 340 W @ 4 Ω
Shouldn't be an issue.
For a std 4 ch amp 2 ohms stereo (4 ohms bridged) is the minimum stable impedance, and the highest stress level for the amp, but a quality amp should run fine.
All ch at 4 ohms stereo would be the lightest load, and even cheap amps will run at that impedance at or near full volume without any issues.
one pair at 2 and one at 4 would be somewhere in between. If your amp is any good at all it should run w/o a problem.
93dakota
93dakota
Ohio U
n2audio
