rta/tuning questions
Etac
Angry Bunny Killer
ok im gonna attempt to rta my speakers in a little bit
long story short - when rta'ing - is it better to run one frequency at a time compared to a sweep
and when you run a sweep is it better to run a real quick one (like 1 second) or is it better to run a long sweep (30 seconds - 1 min) ect..? the results are somewhat similar but i noticed if i run a slower one.. the response seems to be a bit smoother..
ok two more questions -
1) right now i got an omnidirectional mic - wasnt sure if that was the right one to choose instead of a unidirectional one... i figured it would be better since it might help pick up reflections when tuning.. so if this is incorrect plz let me know so i can exchange it =)
2) i have to do a general tune.. - timing cant be done right now- i dont the equipment for that (one day) so when positioning the mic - i figure it has to be in the middle
but is it better to aim the mic towards one speaker and tune it like that.. aim it upright... or forward.. ?
Omnidirectional mic will work fine.
  1. How I tune...
  • Use your Time Allignment set to correct locations (If applicable)Find your furthest speaker away from your location and mesure all others off that one. Do not adjust subwoofer.
[*]Use a lvl setting mesureme
  • Set your individual lvls based on Left and right speakers of same type. (L tweeter & R tweeter, L mid & R mid)Using pink noise or a tone to mesure each speaker individually and adjust your settings to make them match at the drivers seat.
[*]Tuning time
  • If you have a combined L & R EQTurn all speakers on and play your pink noise. EQ entire system as flat as possible. Note your high dips and peaks. Write down your mesurements/settings.Once you have a flat response start to adjust to your personal tastes. Again Write down your personal setting/mesurements
[*]If you have independant L & Right EQ
  • Turn all speakers off on one side. Play pink noise and tune flat responce. Write down your settings.
  • Repeat above with other speakersOnce you have flat responce, turn all speakers back on and tun to fit your personal tastes. You can do this independantly, but I find it works best if you switch back and forth between all on and each side on independantly.
[*]Listen to multiple styles of music as well as spoken words well recorded to determine if you need to go back above and readjust.
Etac
Angry Bunny Killer
Etac
Jersey
Chevyaudio
