RSD 6.5 cutout.
Pl8er
Can you solve it?
The last few days I've been having a problem with my passenger side comps. It sounded like a short or the speaker blowing. If I turn the volume up, it gets really fuzzy then starts playing clear. If I turn it down, it won't play at all.
I have so far:
Re-secured the speaker wire on the amp and on the crossover and flipping the RCA's over hoping if it was a short on one of the RCA's it would switch to the driver side (it did not).
So where should I go next? When it cuts out, the whole thing cuts out (not just the midbass or tweeter) Could it still be a loose speaker connection inside the door?
I had a similar problem with coax. speakers when I rolled my window down. I had to revamp my wires and pretty much do the whole thing over. It got doubly worse when it rained. I know it's a PITA but try checking all your wires.
Thanks. I'm visiting my parents for Easter so I will rip it apart while I'm there.
Thanks for the help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
+1 for you man. I took the door apart and sure enough I had some build-up on the terminal and it was barely making contact.
Problem solved //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks again.
Pl8er
Can you solve it?
Pl8er
Ahwatukee, Az
Dingleberry
Mike Mccabe
