rockford or kenwood?
RollinRemz05
Which is better? Im looking for a really good amp which one of these amps are the best or is there something better i should find?
Brand New KENWOOD EXCELON KAC-X522 2 CHANNEL AMPLIFIER
1,000 Watts Maximum Output Power
125 Watts x 2 (20-20KHz, 0.05% THD) @ 4 Ohms
250 Watts x 2 (1kHz, 0.5% THD) @ 2 Ohms
500 Watts x 1 (1kHz, 0.5% THD) Bridged
High Performance 2-channel Power Amplifier
A.M.S. (Amplifier Management System) -Built in Parametric EQ Control
AMP Information Display (Voltage, Current, Temperature, Cooling Fan Speed) Built-in Variable Low-pass/High-pass Filter
Built-in Infrasonic Filter
Gold Plated Input/Output Terminals
Line Output Terminals (RCA) for Extension
2-Speed Cooling Fan
Detachable Aluminum Dress Plate
OR
Punch P5002 features:
Focused high mass cast aluminum heatsink
ultra stable into 2 ohms
Remote punch EQ nob 0 -18 db @ 45 hz
Illuminated RF logo
Stealth panel hides connections
4 AWG C clamp for power and ground
Thermal sensing circuit Infrasonic filter gets rid of damaging subsonic frequencies CEA 2006 compliant
1500 Watts Max 125 x 2 RMS @ 4 ohms
250 x 2 RMS @ 2 ohms
500 x 1 RMS @ 4 ohms 171 x 2 RMS average output
313 x 2 RMS average output
626 x 1 RMS average output
12 db per octave HP/LP/AP @ 40 400 HZ
2.4" x 11" x 13.7"
OR
KENWOOD KAC-7252
MAX POWER OUTPUT: 1000W
SENSITIVITY: 0.2V
INPUT IMPEDANCE: 10k Ohm
FREQUENCY RESPONSE: 5Hz- 50 kHz
DIMENSIONS: 380W x 61H x 286D mm
THANKS.
Im not sure yet i only have 2 12" Dual subs in the bandpass box the subs are 1100 watts peak and 400 rms. Im planning on getting new subs soon something more powerful. Theyre going to be 12" im not sure what to go with yet tho.
Get peak power out of your vocabulary. Rms is really what you look at.
As far as amps, I would go elsewhere. Alpine makes nice decently priced amps. Then you can switch over to alpine type r's with are very decent subwoofers.
RollinRemz05
RollinRemz05
Toms River, NJ
json_35010
