RMS Equation?
the formal equation is:
power, rms = (1/T) * integral( (over T) of (v(t)*i(t)) )
voltage, rms = (1/T) * integral( (over T) of (v(t)) )
this is typically overly complex for most cases. there is another equation as well, but its less useful.
typically you deal with sine waves. sine waves (into a resistive load) have an RMS value that is 0.707 * the peak value. in terms of power, that would be RMS power = 1/2 that of peak power.
square waves have an rms value that is the same as the peak value. not too hard of a wave.
RMS defines the "DC equivilent". basically the power to the speaker is constantly changing. the RMS value is the simplified value.
In car audio terms, power = volts ^ 2 / impedance.
If an amp maxes out at 20 volts (unclipped) and is on a 1 ohm load, you have 20^2/1, or 400 watts.
Clipping can seriously screw with the reading a DMM takes, so make sure you aren't clipping or you'll get some seriously freaky number. I pulled around 56 volts out of a 600 watt power acoustik amp before trying to do this. Needless to say, it was not possible for me to clip it any harder. =\
JeffyZ33
not******
JeffyZ33
In A Tree
Raven
