Rivet nut/nutsert
Assuming you are talking about riv-nuts like they use in the auto industry(A threaded nut that you crimp into place that accepts a bolt). You could use a small piece of sheet metal to beef up the area you plan to attach them just to be safe. If you are talking about regular rivets just use a fender washer.
Get some jack nuts or grip inserts.
I will have to look into jack nuts. Never heard of them. Grip inserts look like rivet nuts but the outside diameter is splined right? I was afraid they wouldn't hold well.
What rivet nuts do you have? I have a kit that works fine in sheet metal like that.
It's an old Mac tool kit. Can't even find the original nutserts for it. Or a replacement mandrel. There is just a few random nutserts left and two of them happen to be just what I need but the kit only recommends that size nutsert for .200 and larger. That is thick as hell. It's a 5/16-18 nutsert.
noble brown
noble brown
Hermitage, pa
noble brown
Mike Mccabe
