ring terminals
slide the terminal ring onto the wire....solder around the bottom of the fitting and the wire, and the top of the fitting as well.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
they actually make pre-soldered terminals...just have to put the wire in, and it melts on... They are used for bigger truck applications..
Besides that.... if the terminals are closed at the end... put a bunch of solder in the terminal...melt it all with a sharp flame mini torch...keep feeding solder in it until its about half full, then quickly stick the wire in there and it should be fully soldered to the top... once the wire is in...careful if you try to add more solder because you will melt the wire coating.
Tin the end of the cable, then stick it in a set screw ring terminal and heat shrink it on. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What he said if you use a closed end terminal. This is the best way to solder them in. It works best if you have a vice to put the terminal in so you are not trying to hold it with a pair of plyers, heat the solder and then insert the wire.
p3bumpin
p3bumpin
Brier Hill, NY
QtrHorse
