D1g1tal V3n0m
So after running fine all day long I get in my car to leave work (It is 15 degrees outside) and I notice my right channel is working great but my left channel is very very very low. Why?
I swapped the RCA channel from L to R and back
I pulled the power wires from my amp to my crossover and swapped them from L to R + and -
I then go and pull my head unit and try swapping my RCA there as well as swapping it from Front output to Rear output
I swapped the Crossover for the components with a new Crossover I had (Same model/brand)
Still getting the very very low volume ONLY on the left Tweeter and Mid.
I am still getting the normal and great output from my right components but my left is very very low (I have to adjust balance all the way to the left and turn volume up to barely hear it). The sound is extremely recessed on top of being low (Though I am sure they go hand in hand)
I've checked everything that I can (15 degrees outside working on this sucked.) The tweeters were both hooked up using silver solder and wiring the tweeters wire to the stock tweeter wire and then splitting at the HU Harness to the crossover. The Mids had all new 16 gauge wire ran to them.
The set up ran fine for a few weeks before now the left side going near silent.
So with that said.... Any ideas?
