Southeast Region Richmond, VA - 08/26/2012 Likuid Glass Kustomz & Team Deadly Hertz Bass Off
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
Good thing I didn't cut it out yet...That would have been 4 batts for sure:suave:
no doubt i just realized i only have about 3.3 after disp of sub and port at 36hz. kinda small //content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
i may just reverse mount my subs if im wrong lol but i made a mistake on the calc.
@JayDubb757; just take 1 inch off the rear port wall leave everything else the same. here is the terminal where i want it
make sure the port isnt in the way so my fat hands can change the wire.
if i get to stay i go if not ill just come pickup the box n leave //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
hoe go anyway
Since I am so close to you I am sure we will get some quality hangout time. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
//content.invisioncic.com/y282845/emoticons/spank.gif.0d78e34d42ea8780359e903aeb6697d6.gif
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
662
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
JayDubb757
JayDubb757
Hampton, VA
JayDubb757
    May 16, 2024
    May 16, 2024
