RF BD1001 specs?
Thanks, I assumed it was underrated but I couldn't even find the manufacturers specs... Until I thought to check RF's site. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
The 1100+ is PERFECT for what I need.
Anyone know if these amps were fairly efficient, or are they pretty power hungry?
Thanks, I assumed it was underrated but I couldn't even find the manufacturers specs... Until I thought to check RF's site. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifThe 1100+ is PERFECT for what I need.
I have the older and newer power bd1000.1 and they both rock!!! I have had the newer one tested a couple times and the last time i did, it ran just at 1,650 wtts rms but @ 1 ohm. they are both very underrated IMO and according to the spec sheets.
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
Class bd technology
requires 4-gauge power and ground leads and a 100-amp fuse and fuse holder wiring and hardware not included with amplifier
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz) gives you fingertip control of your bass impact
bd Sync allows you to bridge together two separate Rockford Fosgate Class bd amps (with an optional cable) to power one woofer
subsonic filter removes frequencies below 20 Hz for increased efficiency
13-1/8"W x 2-3/8"H x 9-7/8"D
JeepSound
vtec-lol
JeepSound
B.C,Canada
Evilkefz
