Review: Autotek MX-1300 amp
mattj
Resonant Engineering
One look at this amp and you know it means buisness. 26 pounds of this really nicely finished amp measures in at 26 x 16 x 2.5. This amp is loaded down with features like you wouldnt believe. Everything from LP/HP filters, Autoteks "bass thrust", 70 x 2 fuses, internal fan, 2 awg power inputs, 10 awg speaker inputs, and not to mention' they are stackable so you can get over 3200w from these bad oscars with 2.
The following are the output at 1khz:
4 ohm at 12v - 375 x 2
4 ohm at 13.8v - 380 x 2
4 ohm at 14.4v - 390 x 2
2 ohm at 12v - 650 x 2
2 ohm at 13.8v - 662 x 2
2 ohm at 14.4v - 670 x 2
1 ohm at 12v - 800 x 2
1 ohm at 13.8v - 823 x 2
1 ohm at 14.4v - 838 x 2
Mono Bridge into 4 ohms at 14.4v - 1200 x 1
Mono Bridge into 2 ohms at 14.4v - 1600 x 1
Stable at 1 ohm
Maximum Current Draw - 156a
Fuse Rating - 70a x 2
Power Supply - Full PWM
Output Power Circuit Configuration - BIPOLAR
This amp is really an asskicker. I compleatly melted 2 Polk/MOMOs with it and melted the coils on a few other pairs of subs. As far as sound iwas preaty impressed. It isnt a sloppy spl amp. The only bad thing about this amp I can really say is that it is a little power-hungry and the fact that it weighs 26 pounds. Ive never had any problems with this amp, and I picked it up preaty cheap compared to everywhere else on the internet selling it for 700+. The retail on this amp is about $1300
Sound Quality - 4.3 / 5
Efficiency - 4.5 / 5
Current Draw - 4 / 5
Overall - 4.3 / 5
Conclusion: Like I said before, this amp REALLY is an asskicker. Weather you are an everyday driver or would like to compete, this amp can walk the walk and talk the talk for you, and anything within a 5 car radius. This amp has the capability to piss a lot of people off in your local area. This amp impressed me and I am not one to be impressed easily. Deffinetly an excelent amp for anyone who needs power.
mattj
mattj
Wisconsin
xtdan
