i need help?????3333
abcdefg
yes i have a question i have a 1200 watt max amp 2ohm stable and two 15 inch dual voice coil at 2ohm subs at 300rms a piece, can i run two wires from each positive and negative on each channel and run it to one sub on each voice coil and then other sub use the other channel and run the two wires to each voice coil will that work??? will it mess up my amp or even my subs???????? thankyou
abcdefg
abcdefg
Clarksville, Tn
abcdefg
