reverse camera caution stays on
heyhi1
I installed a reverse camera to a pioneer p1400 dvd unit. The camera works when put in reverse and camera shuts off out of reverse but the problem im having is no matter what polarity i set it the caution stays on. What could the issue be?
disconnect the reverse wire and see what happens
I disconnected from the camera, both video and power plug . The reverse wire is still spliced should i completely cut the power wire?
Same problem caution screen comes on but when i shut the camera option off from the unit it goes away.
Its wierd cause with everything hooked up, camera turns on in reverse and off out of reverse so it seems like its the correct wire that im getting power from. Its grounded, i don't get it
heyhi1
heyhi1
nyc
jboy2015
BP1Fanatic
BP1Fanatic
