retuning a slot port
wevie
Greetings,
A year or so ago I build my first enclosure. I was using a Kicker CVR (yeah, I know, but I was learning) and built the box to the owners manual's specifications. I later realized that those specs: 2.25ft^3 with 3"x12.5" slot 20.5" long; come out to a tune of about 42 hz!!!
I want to retune the box and reuse it. I'd like to bring the tune down to 32-33 hz. Using the12volt calc, it looks like I could change the slot to 3"x7.5" at 20.5" long. Would a 22.5in^2 port be too small?
The only way I can see to lower the tune without reducing the area of the port is to extend it outside the box another 16".
Which route would be a better choice?
**I know this isn't an IDEAL situation, but all I am doing is PLAYING around with tuning and LEARNING what works. This isn't a permanent installation**
Forgive my newbness... but it's not impossible to extend the port outside the box, is it? I've seen pics of aeros outside the box, why not a slot?
But, if that port area isn't too small for a single 12, its all good for playin' around.
It wouldn't be hard to extend the port outside the box, but I doubt you have an extra 16" to do it...just build a rectangular tunnel the same opening as the port, and glue it to the port opening.
hmm...i now see what you're talking about, I was thinking of it a different way. However, it certainly doesn't seem ideal
That's what I was thinking, too. I can picture it in my head, and I could see it allowing me to try different port lengths, thus different tunings. Then I could learn first hand how that affects the overal "feel" of the system.
True, that would be easier to adjust the tunings...just do like 4" increments to change it ~2.5hz at a time.
wevie
wevie
Iowa
RAM_Designs
