Restoring an old Shocker III motor
woofercooker
A Gentleman and a Scholar
I picked up this motor on the forum. It had the normal wear that a raw steel motor gets over the years. I started by sanding off some of the impurities and then laid on a few coats of paint. Here are a couple of pics of the motor masked off and drying.
Next the motor arrived with quite a bit of debris in the gap which needed to be cleaned out. Also all of the mounting holes were stripped clean and needed to be re-threaaded. I took care of that with a simple tap and die set and was able to get the basket all mounted up. Going to make it into a nice beefy little 10 for my collection.
More to come as I put the recone together.
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
woofercooker
woofercooker
Rochester, NY
woofercooker
Decebal
    Jun 10, 2024
