Resistance Problems
I appreciate the actual help you are providing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
I already have backed the gain down a notch.
Here's my plans:
Run 2-3 more cheap batteries inside the trunk (I'm broke, leave it alone please).
Run my 8ga kit to said batteries with a 40a fuse as a charging wire. Run 8ga from those batteries to my amplifier.
Wouldn't that help solve my issue?
My other thought was to run a 2ohm resistor and wire it in series with the sub in the meantime. I don't know if that'll work though.
skip the batteries
do the big 3, run a bigger power cable to your amp
OP I was running almost 1k rms on a battery that sat at less than 11 volts with the car off, and wouldn't hold a charge above that, and a 60 amp alt...Unless ur amp is as efficient as rectangular wheels, you shouldn't be having issues pulling 600 watts especially on music, you probably have a bad connection somehwere or are running 220 gauge power wire to your amp or something
The problem isn't my alternator (to the best of my knowledge). I belive its my cheap battery up front. Its a Bi-Mart special for $25....300cca on it. My car is supposed to REQUIRE 400-500 or something like that. So I think I just need a few more of those cheap batteries.
dont get more cheap batteries man
get one good battery up front
big 3
bigger power cable
Here's my plans:
That isnt that much power...you should be fine with replacing your battery with a higher-performance one and also upgrading all of your wiring (Big-3 etc.) as well..
And the resistor idea=no...keep in mind the resistor is *technically going to get half of everything being put out by your amp and will need a pretty high power rating to sustain it (it'd have to be a large resistor)...and also, by having it take half the power, you arent much better off than running it at 8 ohms...or just back the gains down and turn off the bass boost
big 3
bigger power cable
You keep saying big 3. What is that?
So what can I do for a GOOD battery that is inexpensive? When I say I'm broke, lol, I don't think you understand. I work 2-3 days a week min. wage to support 2 people. I'm BROKE. I'm just trying my hardest to piece this thing back together to work properly.
So get a good battery up front. PROBLEM: I've got a 91 Buick Regal. That means a small side post battery is needed. Can I get a good battery that fits that description?
And I'll get bigger power wire last. That's the last thing on my mind.
big 3 is upgrading your stock electrical by ADDING power/grounds
alt to battery positive
battery negative to chassis
chassis to block
Gain is almost ALL THE WAY DOWN at this point, and bass boost is 100% off. Crossover is set to 60Hz. I understand that the resistor idea would mean it'd get half. So running at 8ohms would be better than having a resistor pulling on it? When I had two subs (2ohms per sub, 4ohms at the amp), they got plenty of power (not enough.....but enough for my ears).
why do you have the x over @ 60hz
What im saying is if you put that resistor inline like that youre pretty much putting a 2 ohm sub inline with it (a sub is just a resistor in a circuit...but converts the energy into mechanical AND heat...where as the resistor is just converting it into heat/thermal energy)...
Just like if you have two SVC 2 ohm subs in series...and your amp is rated at 800 rms @ 4 ohms...that means each of your subs will get roughly 400 rms a piece (and if it wasnt that way, that means youre creating energy...which no one besides me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif knows how to do)..
What im saying is if you put that resistor inline like that youre pretty much putting a 2 ohm sub inline with it...
Yes, I know that's exactly what it does //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. I have a little background in electrical. I'm just trying my best to find the RIGHT way to fix this...but inexpensively.
And about 3 days ago I HAD two of these subwoofers running at 2ohms apiece, 4ohms at the amp. Which is the reason why I was thinking a resistor. I already know what the power is like when there's two of them. And this box is 10x better than the sealed crap boxes I had before.
pioneerisloud
pioneerisloud
Yakima, WA
TurdFergueson2
