I don't know how to replace the stock headunit on an '04 dodge. I know how to wire up an amp and stuff, but dunno about the headunit. I have an Alpine 9884 that I want to put it. What all do I need? Instuctions? How hard should it be?
The parts you buy at walmart are Scosche. It ant the best but they do the job just as good as a really expensive part. A wire harness is a wire harness. As for there dash adapters I don't see what you could really do yo make it better other then use stronger plastic which unless you plan on kicking your dash it isn't going to do anything.Dont just pull on it, there is a screw you need to remove first.I wouldnt use walmart parts they ****, BBY has them but they will be expensive.
