Replacement 8" sub meeting these specs
drwang
My Dad's Ford Expo's Mach Audio subwoofer stopped working. I will be removing the stock 8" subwoofer and need some help finding a suitable replacement for the stock enclosure.
The only sub I've found so far that meets the requirements is the MTX Thunder4500 8" :
http://www.crutchfield.com/S-BPWdxhzxcW8/cgi-bin/ProdView.asp?g=520&tab=essential_info&i=236T4508#Tab
And the spec requirements are:
# 8" 4-ohm subwoofer
# power range: 80-100 watts RMS (b/c stock amp is rated ~85rms)
# sensitivity: 86.6 dB
# top-mount depth: 3-3/4" (most important)
THANKS!
The mach 5, and the parts express woofers all have mounting depths that won't fit in the stock enclosure.
Kicker isn't all that bad, I used the old black square 12" L7 back in the day, and it produced some loud bass but give up a little sound quality,still not all that bad.
I'm throwing in another option, the Fosgate Punch 8".
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=14232
Still looking around, thanks for the help guys.
Where is this mach 5 8?
Contact Don (6spdcoupe)
The rainbow x-line will fit in that space.
The rainbow speakers most likely are out of my budget. I won't have money to replace all of the speakers so I don't really see a point in getting an expensive woofer to match the stock speakers. But thanks for throwing out that option and that rainbow x-line depth of 2.5" is really thin.
youre retarded
drwang
drwang
Bay Area, CA (415)(925)(831)
denim
