reparing gas tank hole?
jb weld should work if it is a small hole.
^^^ Even if it was a bigger hole you could make a patch panel from sheet metal & JB weld it since I'm assuming this is on the TOP of the fuel tank... Be sure to clean the fvck outta the surface area before applying JB or any other adhesive so it will actually bond and last //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hrm are you sure hole in gas tank?
can be evap code from computer which can be caused by a number of things that allow air into the gas system, including vapor seal on gascap being cracked or out of place, small hole in the hoses.
went to Pep Boys, picked up some Gas Tank Repair.. just some crap you gotta knead together and apply. vapors are gone and so is the gascap light
---------- Post added at 08:18 PM ---------- Previous post was at 08:17 PM ----------
Then that would be your fault. Common sense should tell you that you shouldn't put a flame near gas
lol @ your sig quote
Ive been in a Dodge 2500 with that 5.9l Cummings and witnessed it turning on the 1Mill. Mile marker, and still ran great a couple years later.That...
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
4K
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
Slo_Ride
SPLBassJunkie
    May 21, 2024
    May 20, 2024
