removed head unit from 2007 f150
moptopklee
finally got the stock radio out
there was two different harnesses plugged into it
one bigger and one smaller
can i plug the factory harness into the aftermarket pioneer or do i have to use the one that came with the pioneer
and what was the bigger harness connected to the stock radio
need some help dont know much about this stuff
thanks
finally got the stock radio outthere was two different harnesses plugged into it
thanks
You need an adapter to crossover from the big harness to the harness supplied with your pioneer deck. Like this:
http://cgi.ebay.com/FORD-LINCOLN-MERCURY-03-07-HARNESS-METRA-70-5520_W0QQitemZ150210151848QQihZ005QQcategoryZ32812QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
alright thank you
where do i get wiring for subs that come out of the back of the radio cause i was gonna go ahead and wire it so when i do get subs i dont have to rip it back out
alright thank youwhere do i get wiring for subs that come out of the back of the radio cause i was gonna go ahead and wire it so when i do get subs i dont have to rip it back out
You need to read/search here some more. Here are some amp kits that are good and cheap:
http://www.knukonceptz.com/productMaster.cfm?Category=Amp%20Installation%20Kits
and with the wire harness adapter does it require anything special or do they just clip together and you put the radio in the dash
You will have to splice the wire harness adapter and deck adapter together. Then you can just clip it into your stock harness and your good to go.
alright thanks man
you have helped me a lot
but is it possible to wire up for subs and just leave the wire going to the amp unplugged until i get an amp and sub
alright thanks man you have helped me a lot
Definately, just run the wires and wire tie them under the dash, or in the back of the truck or whatever until you get ready to install an amp.
first you need to do some research on how to install a cd player, you will need to purchase a dash kit and a wiring harness adapter, i know circuit city sells 2 harnesses on that plugs into the pioneer and then one that plugs into the stock wiring then they clip together. and you need to learn to solder if your going to just get the one harness and use the stock pioneer harness. use electical tape over the connections. what subs and what amp do u plan on running?
moptopklee
moptopklee
Union, Ky
THUNDERBIRD
