Remote Wire Problems
CruzeLow85
CarAudio.com Newbie
First off, hello all!
I have an older install that is driving me crazy and need some help.
2 10" soundstream 300rms @ 4ohm each
1 soundstream 175w per channel 2 channel amp
4ga B+
4ga Ground
I recently bought a Rockford fostgate R500X1D amp to add to power as the amp I had was underpowering the current subs. The current amp powers and plays fine running each sub at 4ohms. The problem is when I pull the old amp. When I wire up the new amp  @ 2 ohms will not power on. I thought it was DOA so got another one (same kind). The new one won't power on also. I spent all of last night checking all connections to no avail. B+ gets 12v, Remote gets 12v and ground is good. Swap back out to the old soundstream and it powers up fine.
Update:
I messed with it this morning and noticed that if I put power from the B+ to the remote the amp comes on. The remote wire will still turn on the old amp no problem.
Should I just run a new wire from a fuse instead of from the remote lead on the HU?
Has anyone seen this happen previously?
CruzeLow85
CarAudio.com Newbie
CruzeLow85
CruzeLow85
