Remote Starter on a manual tranny
Thanks for the info guys. Forbidden, I have installed a couple already with no problems, just no manual trannys. I use the DEI 555U bypass, and have never had a problem. Thanks again guys
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
343
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
birsling
Out of the game too long!
birsling
Spring Grove, IL
birsling
    May 18, 2024
    May 16, 2024
