Remote Starter HELP
Ok I have a audiovox 5 button alarm with a option button that im not using and i want to connect it as a remote starter when you press the button the option wire in the car gets 12 volts How can I connected to remote start?
It would be unusual to have an option output that delivers 12 volts. Usually they pulse ground, instead. You might want to double-check that.
In addition to a remote start unit that includes the correct type of activation input, you'll also need a relay to interrupt the ignition input at the alarm, and another to interrupt the shock sensor input. Otherwise you'll need to disarm your alarm every time before you activate the remote start.
I just want to disarm the alarm and start the alarm from close like in a parkinglot
It just has 1 wire where do i connect it to the run wire or the start wire or is it not possible.
You connect it to the remote starter's activation wire, either (+) or (-) depending on the polarity of your alarm's output.
If you're asking if you can remote start the vehicle using just that wire, then no, you can't. You need to purchase an add-on remote start unit.
SOundin LOUD
SOundin LOUD
New York
KaeZoo
