k_schutte
OK, When I bought my Bravada it had a remote start hooked up but did not come with a fob or anything. I tried to find a replacement but it is an OLD unit so they are no longer available... SO, I got hooked up with a "Valet" 561R unit and am attempting to do it myself. I got most of it done but not all of it and I can't get it to do anything.... here is how I have it wired...
wiring for Bravada can be found here:
http://www.tune-town.com/free/1998_OLDSMOBILE_BRAVADA_%204DR%20
SUV_wire_diagram.htm
or
http://www.the12volt.com/installbay/alarmdetail/1700.html
harness/wire - color/color (what it is for/what it does) -- what I have it hooked up to
Primary harness (H1)
h1/1 - Light Green/Black (factory disarm) -- Not hooked up
h1/2 - Green/White (factory rearm) -- Not hooked up
h1/3 - Yellow (+ ignition out [to alarm]) -- PINK ignition harness switch
h1/4 - White/Blue (- activation input) -- not hooked up
h1/5 - Gray/Black (- wait to start input for diesel) -- Not Used
h1/6 - White/Red (+ activation input) -- Nopt hooked up
h1/7 - Red/White (Channel 2 [validity only]) -- Not hooked up
h1/8 - Black (ground) -- Grounded to chassis (good ground, i checked it)
h1/9 - White (+/- Light Flash) -- Not hooked up
Heavy Gauge Relay Wiring
1 - Pink (+ [30A] output to ignition circuit) -- Pink, Ignition switch harness
2 - Purple (+ [30A] output to sterter circuit) -- Yellow, Igntition switch harn.
3 - Orange (+ [30A] output to acc. circuit) -- Orange, Ignitionswitch harness
4 - Red ([30A] 12V input) -- Red, ignition switch harness
5 - Pink/White (programmable output for acc. or ign.) -- Not hooked up
6 - Red ([30A] 12V input) -- 10gauge direct to battery
Door Lock Harness
1 - Green (- lock output) -- relayed to + to lt. blue "lock" wire in door
2 - Empty -- Not Used
3 - Blue (- UNlock output) -- relayed to + to white "unlock" wire in door
Remote Start Harness
H2/1 - Black/White (- neutral safety switch) -- grounded (temporarily)
h2/2 - Violet/White (tachometer input) -- White aire on ignition coil (tach)
h2/3 - Brown (+ break switch shutdown wire) -- White wire on brake switch
h2/4 - Gray (Hood Pinswitch shutdown wire) -- hood pin switch
h2/5 - Blue/White (- 200mA 2nd status/rear defog.) -- Not hooked up
or
Door Lock Harness
