Remote start install help
verick
A 2007 Dodge Ram 2500 Diesel remote start install. I'm installing a 791xv. I'm using a 556uw for the key bypass, but I need help on wiring the relays for the Start wire/ ACC and the parking lights with resistor resistance number? Someone told me about a CHDL7-PK2 module. This install is driving me crazy, but it would'nt be the first one to do so. Thank you so much in advance.
- Also where I can get a Tach Generator from DEI. for a 2007 Ford f-350 Diesel install I'm doing later.
i believe this is your vehicle? hope this helps you
DODGE / RAM PICKUP / 2007 / Remote Start
12volts lt. blue/red (2A) + ignition harness
Starter yel/gry (not for remote start) + near battery, gray plug
Notes: There is no positive starter wire required for remote start. Just use the negative second starter wire.
Second Starter purple/brown - ignition harness
Notes: The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Ignition pink/white + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter wire
Notes: The accessory wire is negative trigger thru a 610 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Accessory N/A
Keysense N/A
Power Lock purple/dk. green - DKP or cluster, sml gry plug, pin 3
Notes: Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Can also use Directed interface module.
Power Unlock same as power lock wire
Lock Motor lt. green 5wi DKP or cluster, white plug, pin 10
Unlock Motor tan/lt. green 5wi DKP or cluster, white plug, pin 1
Parking Lights+ white/yel (L), white/gray ® + harness at top of driver fender
Parking Lights- white/lt. green - sw or cluster, sml gry plug, pin 5
Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay.
Hazards white/orange - sw or cluster, sml gry plug, pin 8
Notes: Hazards are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal(L) wht/lt grn (F), wht/dk grn ® + harness at top of driver fender
Turn Signal® white/tan (F), white/yel ® + harness at top of driver fender
Reverse Light white/lt. green + harness at top of driver fender
Door Trigger see notes - each kick or cluster, lrg gray plug
Notes: The LF door is purple in pin 1. The RF door is purple/white in pin 4. The LR door is purple/orange or purple/gray in pin 2. The RR door is purple/yellow or tan/yellow in pin 3. Use all four wires and diode isolate each wire from each other and the instrument cluster. See DirectFax document 1076 for wiring information.
Dome Supervision yellow/lt. blue + A pillar or cluster, wht plg, pin 21
Trunk/Hatch Pin N/A
Hood Pin purple/lt. blue - hood pin switch
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer dk. blue/gray ac PCM, black/orange plug, pin 34
Notes: The PCM is on the passenger side firewall. The black/orange plug is the second plug down from the top.
On SRT-10 models, the tach wire is in the top black plug, pin 18.
On diesel models, the tach wire is at the ECM on the lower driver side of the engine, front 60 pin plug, pin 24, or at the camshaft position sensor just left of the ECM, in a 3 pin plug.
On gas models, can also go to any ignition coil or fuel injector and use the wire that is NOT brown/white.
Wait to start see DirectFax document 1091
Notes: On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wire white/tan + brake pedal switch
Parking Brake dk. green/white - sw or cluster, lrg gry plug, pin 22
Horn Trigger dk. green/purple - sw or cluster, lrg gry plug, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Thank you Mexican3001 for your help with 2007 Dodge wiring, but I have one more favor, do you know where I can get the Directfax documents 1076, 1084 so I can print them out. Thank you again Verick
you should find a dealer that sells fortin products. use two modules. A cansl and a patschysler04+ it'll make your install a breeze.
DEI doesnt have a diesle timer on thier units? sucky. i know cs does. huh. good luck bro.dont forget to hook up your 12 volt last. just a friendly tip
verick
verick
Houston, TX
dswift
BP1Fanatic
BP1Fanatic
