REM hook-up
  • 2
joesf
Alabama
I was woundering if their was a way I could hook my REM to the fusebox so that when I turned my key on the amp would come on and when I turned the key off it would go off this way I could hook up a mp3 player to the amp and later buy a CD player and then hook it to that Thanks
Yes.. For a second amplifier you can use another 16-12ga single wire from the 1st amplifiers remote wire location and use a second wire to go to...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
494
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
joesf
joesf
Alabama
geonn
