Refurbished specs different?
solidcrowd
I was looking at the refurbished kicker zx1000.1's on ebay and i found these specs to be different from another
First:
Amplifier Type 1 Channel
RMS Power: 500W x 1 @ 4 ohms THD at 4-Ohm RMS Power:
RMS Power: 1,000W x 1 @ 2 ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 25-200Hz
Signal to Noise Ratio: 60 dB
Fuse Rating: n/a
Advanced chassis with extruded aluminum heatsink
Efficient class D circuitry
Top-mounted controls
KickBass 0-18 dB variable bass boost at 40 Hz
Variable 50-200 Hz low-pass crossover with 24 dB/octave slope
Defeatable 25 Hz subsonic filter
High level or low level inputs (125mV-10V)
PreAmp Signal Transfer (PAST) RCA outputs
Delayed turn-off logic circuit
Soft start turn-on circuit for reduced startup load
Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection
Included remote KickBass control
Fully CEA-2006 compliant specifications for real-world power
Second:
Specifications :
Class D Mono 1 channel Design
1000W RMS X 1 @ 2 ohm
500W RMS x 1 @ 4 ohms
Gain and crossover frequency control
Top Mounted controls make it easy to adjust this amp at any time
Protection light indicator
Mosfet Powered
Soft Start turn-on
Protection Circuit
S/N Ratio: >95 dB
Built in crossovers: 24 dB per octave low-pass crossover (50 - 200 HZ)
Bass Boost (0-18 dB)
12 dB defeat able sub sonic filter
Free remote bass boost
Frequency response 20-20,000 Hz
Equalizer for bass w/ variable gain that goes up to 18dB
4 AWG Power and Ground (recommended)
Dimensions: 9-5/8" x 2-1/8" x 16-3/4"
Which one is better if they are actually different??
solidcrowd
solidcrowd
Buffalo, New York
solidcrowd
