ref405s power question
ep3civic1212
25
ny
the soundstream reference 405s amp is rated at 25x4 and 100 watts @4 ohms on 12 volts of power, i was told that the way these amps are designed, at 14.4 volts regulated, those numbers would increase considerably, does anyone have the exact specifications of this or is it just speculation. Also numbers at 2 ohms, 1 ohm etc, thanks.
This is in German, but they do measure the amps.......
Soundstream Reference 405
High-Power-Mode
1 × 42 Watt Kanal 1 an 4 Ohm
2 × 34 Watt Kanal 1 + 2 an 4 Ohm
4 × 32 Watt Kanal 1 bis 4 an 4 Ohm
4 × 28 Watt Kanal 1 bis 4 an 4 Ohm +
1 × 121 Watt Kanal 5 an 4 Ohm
4 × 27 Watt Kanal 1 bis 4 an 4 Ohm +
1 × 190 Watt Kanal 5 an 2 Ohm
High-Current-Mode
1 × 77 Watt Kanal 5 an 4 Ohm
4 × 25 Watt Kanal 1 bis 4 an 4 Ohm +
1 × 120 Watt Kanal 5 an 2 Ohm
4 × 23 Watt Kanal 1 bis 4 an 4 Ohm +
1 × 182 Watt Kanal 5 an 1 Ohm
ep3civic1212
ep3civic1212
ny
Rich B
vegang
vegang
