recone guys need help
yup your recone is bad. The rub will probably get worse over time and eventually break.
when i slightly press the surround on the right side, the rub goes away..... most probably i will have to reglue the surround properly onto the gasket.....
i need some info.
1) same coil size / diameter / 2 layer , but with a fatter wire , will give me more ohms or less? mayb i used the wrong wire gauge?
you have to push dead center. pushing to 1 side or another depending on how tight the gap is it will rub.
hummm. yes mayb thts one of the main reason y its rubbing. all in all, sounds pretty decent.... but keeps on smelling like a dry fish... (the previous burnt coil smell is still there)....
enerlevel
enerlevel
asia
enerlevel
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
