Recommendations for truck sub
Mcflyfyter
I have a 2007 F-250 crew that I am planning a box behind the back seat. Will be running a GM-D8701 (500@2 ohm, 800@1ohm). I can do an easy box 3' long at 1.3cf, or I can bump it up to 2cf with significant effort. These volumes are internal without accounting for anything. At these dimensions I will have to countersink the subs so they don't hit the seat, but I think the extra volume would be worth the effort. I wont have a lot of depth, probably 5.75 for a 10". Just looking for decent sound in a ported box and keeping woofer(s) under $250 or so. I havent bought a sub In 15 years, so I have no idea what the best values are today. Thanks for any input or thoughts.
I put two VFL8's behind the seat of my standard cab Dodge.
I ran a standard cab dodge for many years. Sealed box with 2 MTX 12"s. Ran about 400 to each of them and it was LOUD. I think it was about 1.6ft3 for each sub. They were only rated for 250ish but took the power fine in a sealed box. The only downfall was the whole bench seat had to be removed to install and remove the box! Well worth the extra effort and on a budget!!
There is a boat load more space behind a single cab. I'm looking at 3.25" deep at the top and 8" at the bottom, and that is the box touching the seat back. I'm thinking about setting a section back 1.5" for the woofer, and have the rest of the box touching the seat. I guess I'm going to build the box and see what I come up with for volume, then go from there.
I installed the amp yesterday, and now have 300 rms into a fosgate P2 in a sealed box. I found the sub and box in a dumpster and reglued the surround and a few screws in the box and it is pretty impressive. I'm hoping 500 into a ported box will be noticeably louder.
Two American Bass VFL8's @ 1ohm on a DD M80 (900@1 ohm). Sub up port up and behind the seat. I'm 5'11" and drive very comfortable. Box is 9.5" top and 10.5" bottom. Loud and cleanView attachment 19540
My box is 3.25" top and 8" bottom. Seat has to be removed to install box. I recessed the woofer baffle .75", but I think I'm going to have to go another .375" (essentially flush mounted) and thin a portion of the back wall. That is with a shallow mount 12" at 3.75" depth with a 6" magnet. I have high hopes...
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
439
Doors and dash? Year, make and model of the car? Amplification? Midranges or coaxials? Need some more specifics about what if anything is already...
363
Heck...done right...you could get an amazing sounding stereo using $15-25 drivers from partsexpress 😂
628
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
I read your post and thought about all the aftermarket decks that were installed using the factory power wire. This is why manufacturers quit...
92
5K
Mcflyfyter
Mcflyfyter
Black hills
Mcflyfyter
DEW123
    May 7, 2024
DEW123
    May 7, 2024
