Recommend me an Amp please
westbank1
To start, I'm a newb to car audio. My Kenwood 600W amp (Kac 728s) went out on me. I would like some help on what would be a good replacement.
Budget: Would like to be at or under $100.00. ALso, i have no problem searching for a gently used amp on ebay or Craigslist cause I'm not in a huge hurry.
I don't need anything top of the line, just like to have the greatest amount of bass in that price range coming out of my existing subs.
The amp will be powering 2 12" MTX Roadthunder subs in a sealed box. I'm not sure of the wattage on these subs, anyway to find out??. As you can see this is an older system, but just looking to replace the amp for now.
Any help would be greatly appreciated.
Thanks for all the suggestions. Just to clarify though, going from a 2 channel to mono amp, i shouldn't have to wire it differently from subs to amp correct?
Thanks for all the suggestions. Just to clarify though, it's ok to run a mono block for 2 subs?
yes, mono is always optimal for subs. they only time it wouldnt be is if you had a 1ohm load and the mono wasnt 1ohm stable.
westbank1
westbank1
new orleans
kr15
ThxOne
    May 25, 2026
