Recommend a good 15" HT sub
  • 5
psych0ticnemes1
Psych0tic Customs
6,004
Behind You
I plan on building a low tuned ported enclosure and using this for HT as well as in my vehicle occasionally.
For HT use, I have 500rms @ 4 ohms to work with so I would like a Dual 2 ohm sub.
I was hoping for an 18" sub but the 19Ov.2 is out of stock at the moment and have heard it is pretty cheaply made.
I would like to spend $250 or less.
What would you guys recommend?
Thanks.
-Psych0
im currently in the middle of building an enclosure for a MB quart DWF 354 15
its mis properly marked as its a d2 on my Ddm.
i got it for so cheap i had to buy it up and will be running off a 250 rms plate amp in a 3.5 cubic enclosure.
id reccomend a focal, jl w3, dayton HO for HT
Thanks. I decided on a Dayton Titanic Mk III.
Is there a tuning range that would work well for both the car and home environment or should I just **** it up and make two boxes?
You could use the same box for both if it would fit in your car. For home use you are going to want a larger, lower tuned box than needed in a car, in general.
One thing I’ve noticed about reading reviews is those who cannot spell offer very colorful and misspelled adjectives to describe products. Take...
I’ve never owned them but have heard a lot of crossfire products and like them a lot.
22
292
378
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
keep_hope_alive
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
