Recomend AMps
natisfynest
Balls Deep In Your Mom
that can put out around 2500 RMS @ either .5 ohm or preferably 2 ohm
i'm looking to run a single amp to 2 L7 15 dual 2's i figure i wanna give them about 1200 each.
before anyone says a kicker 2500 sorry but $800 is out of the question i wanna stay around $400 if at all possible so give me some options here help me out
Power Acoustik OV1-5500D...my buddy had one and it was badass....$340
Gothic Series 1-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts x 1 chan.
Fully Regulated PWM Power Supply
Wired remote bass level control included.
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost)
High Speed Digital Circuitry
Single channel operation
Bridging Synchronization
System distress indicator
4-Way Protection circuitry
Mono speaker output connector
Nickel Plated Heavy Duty Power & Speaker Terminals
Phase Switch 0-180
Variable low-pass filter (50-150 Hz)
Subsonic Filter (15-40 Hz)
Frequency response: 15-150 Hz
Dimensions: 17.5" L x 11" W x 2.7"H
RMS Power Rating:
Phase Switch 0-180
i actually have the ov2-820 in my truck now lol thanks for the recomendation
my old not newer Orion 2500 would do more than 2500+ at .5 ohm no problems, but at 2 ohms i would defnately look at the kicker zx2500 and ive found zx2500's for less than $800.
yea i was kinda usin ebay as a guidline since its usually the cheapest but then i found one else where for 425 shipped so i am leaning that direction now thanks for the input
you never seen a switch on an amp that says master/slave? you can use to amps together to get a lot more power but at a higher impedance. and you only have to set gains and stuff on one amp.
nope i dont think i have ever owned a nice enough amp to have that feature lol nicest amp i have ever had is a orion xtreme 500.2 as you can see i just joined no to long ago and have been doing a ton of research but somethings are hard to find on here because alot of people tend to get way off subject in threads or spend more time complaining about peoples gramar and spell check lol
o and my electrical will be yt up front 1 2400 or maybe 2 1400 kinetiks big 3 0 gauge only down fall will be 110 amp alt but i am in the process of searching for one that will work in my suv
yea well ive learned who to take serious and who to laugh at i still look here for the simple fact that this is where EVERYONE is lol. and alot of members are very knowledgable ngsm dytboi i know them both personally and they know their shit so i ask here and if you a member on any other sites you will see this same question from me shortly then ill take all the answer into consideration i will look around and see what people witht he same set up are doing hell i will even be on youtube watching videos of similar set ups to compare and see if i like the way they sound
sorry for rambling
my problem is there is just so much going on in this culture its not like what i use to think it was. hell i remember not to long ago the loudest greatest sub i had ever seen or heard of was a RF 152 and when i found out you could replace parts on it i thought they was ahead of their time lol so i still have alot to learn and figure out but im also easy to please in simple i just wanna be loud and would be supper happy if i could do hair tricks(why i dont know)
the kicker zx2500 would be your best bet. You can get a used one on here for around 4-500 dollars. solid amp and puts out 2500+ watts at 2 ohms.
natisfynest
natisfynest
da nati
RNSkipper
