jeeper07
Rebuilding&Reconstruc ting
want mine ? lmk ive got them ready to ship i sent u messages about the elevation speakers earlier on
I have opened it its kinda close. AS for the rear speakers i I cut the plastic cover to make them fit with a dremel. Pretty easy. If i removed them it would look soo ghetto... I'll show u. Leme find a pichave you opened up your door yet? i think you can just cut (or remove) the rear speaker baffle, and it will fit fine. unless older accords have a lot closer grills you should have no problems in front of the speaker.
Yea my 95 car does have them for the front speakers... I already ordered... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif yeeeeeeeee And I'll deal with the nitty gritty cutting when it arrivesi mean the plastic cover BEHIND the speakers (in the doors), if you car has them.
Makes sense... but.... how is the stock tweets running? Active or something?well, i decided it wasn't worth ripping my dash apart. luckily i'm using an external amp so i had to run new speaker wire anyways.
if you're not doing a seperate amp, i'd just unhook the speaker wire at the HU and then do short runs to each speaker. then you know the tweeters are disconnected, and getting the wire that short of a distance (while keeping it hidden) shouldn't be hard at all (much easier than ripping up the dash).
We'll see on Tuesday when they arrive. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifyep, speakers look about like mine (except mine actually made by pioneer), and my tweets in the same location.
as for the plastic thing, you ARE going to have to either cut out the back or not use it at all. i'd just cut out the back if you don't have enough clearance behind the speaker, or remove it if you don't have enoug clearace in front of the speaker. i think you should have plenty of room in either direction, though.
U can screw the speaker into place without the plasric thing??? I didnt try taking it off, so i dont know. But I wouldt think Honda made holes lined up for the speaker in the metal door.... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifas for the plastic thing, you ARE going to have to either cut out the back or not use it at all. i'd just cut out the back if you don't have enough clearance behind the speaker, or remove it if you don't have enoug clearace in front of the speaker. i think you should have plenty of room in either direction, though.
you can screw into sheet metal, but there's no holes predrilled. just mark the spots you want holes with a pen, and pre-drill some small holes, and then screw the speaker on (make sure you weather seal around the edge).U can screw the speaker into place without the plasric thing??? I didnt try taking it off, so i dont know. But I wouldt think Honda made holes lined up for the speaker in the metal door.... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
