Looook mom! No crossovers!
LoudCrownVic
1/1 of Team Team Team
Indeed it has happened.
I have no crossovers. I'm running 3 1/4" horn loaded disco tweeters hot glued to the wiring under my dash... directly in sheer un-crosssed over unison with my Daytons.
If I don't cut the burn at 4khz on the graphic eq it makes the face go numb. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
so the daytons have nothing to supress the metal cones at high frequencies, and the horns have no protection against lows, and there is no way to level match the two?
are you planning to get crossovers?
Actually, with a little work with the EQ it sounds suprisingly good.
No, this is a temp setup until I get some real tweeters. Soon the front stage will be getting 100rms, maybe we'll run into some level probs there. But basically the "disco horns" are extremely hot sounding at 4khz, so bumping down the level at 4 khz makes them blend with the daytons quite nicely.
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
You guessed correctly. It really does sound horrible. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I turned the fader 100% to the front and it sounds overall bad. There is treble, but the stock speakers were most of the work. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
I dont think I have hardly any freq response from the daytons below 300hz. And the tweeters totally break up at a certian volume level.
And, I instaled the drivers side wire at night so when I put my parking brake on it neatly sliced the wire.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
LoudCrownVic
LoudCrownVic
Scales Bump, IL
FoxPro5
