this we agreeMaybe my idea of hot is not what someone else may think is hot...I was not talking about hot enough to fry an egg...warm to hot?..anyways, if it is hot enough to feel like it would almost burn you,or you can smell that hideous electric burning wire scent , then I would think you have a problem, whether it is a speaker wire short, or possible HU ground issue.
Do this ^^I would suggest wiring the rear speaker to the HU front outputs and listen to verify if it is HU problems or rear speaker problems. If your rear speakers are exposed to the pressure from the subs, they could very well be blown. Hopefully it is just a speaker wiring short..
It get's as hot as the amp, as quick as the amp. And by hot yes I mean too hot to leave your hand on it long, after about 30 minutes. That's a guesstimate, I never actually timed it. If you ask me what's going on with respect to the original post, I think the Big 3 is partially responsible for added pressure on the HU to perform. Either that, or it's a wiring issue. The wires on the doors are low grade, I just haven't had time to upgrade them yet, could be sooner than I felt like it though (as in tomorrow). I don't mind buying a new head unit. People here would say the one I have (Sony CDX-GT700HD) *****, but I don't think the head unit was originally the problem. Just as your cars original wiring was not to handle the strain of upgrades in car-stereo component's, I think, ONCE you put the BIG 3 UPGRADE in (with 0 G wire for Christsakes), I don't think the upgraded components, particularly Head Unit's were meant to handle the type of power of such a huge wiring upgrade. That's my theory as to why it's getting as hot as it is. It seems like the only logical choice, besides the amp, but head units are designed to carry the draw from amplifiers. How far are we from topic on this one.Maybe my idea of hot is not what someone else may think is hot...I was not talking about hot enough to fry an egg...warm to hot?..anyways, if it is hot enough to feel like it burns you, then I would think you have a problem, whether it is a speaker wire short, or possible HU ground issue.
and I was not trying to disagree, I actually missed the post where you said they do not get hot and would have worded mine slightly different. I truthfully suspect what has been said here. The HU gets run pretty hard trying to keep up with a couple of subs and with both rear speaker acting up at the same time, you may have hit it on the head with the rear channels going out...but this is one of those that is difficult to diagnose without actually being there to hear the distortion and play with the system.this we agree
^^ This.My HU got hot as hell in the summer. And that was only running rear speakers too. They head unit doesn't get any MORE power with 0 gauge wiring. It makes it easier for the power to flow. The components do not have to strain as hard to get that power. It's not making anything work harder or use more power, it's just lessening the strain. You're way off there man.
And as West suggested, try running the rear speakers off the front channels of the HU and see if you have the same distortion issue.
2nd, I'd just get a small amp for the speakers anyway. They will see more potential with better and cleaning power.
Well, my head unit is out, not detached, out. I touched it, it was hot as hell but not because anything was on, because of how hot is outside.Do this ^^Don't worry about heat, everything is going to run hotter in the summer (your deck sits behind the firewall and you engine will run hotter as well). I have noticed that stock HU's can run very hot as well.
I would, but my fronts and rears are not connected by RCA's there is nothing coming or going out of the in or output jacks, just a huge garbledYou need to isolate the problem by doing what quackhead said. Send the front outputs to the rear speakers.
The rear speakers in question (the door speakers in the rear), can turn up loud, but with twice the volume as the front's. The fronts are clear, theyou may have hit it on the head with the rear channels going out...but this is one of those that is difficult to diagnose without actually being there to hear the distortion and play with the system.
The cause is most likely crrappy Asian manufacturing.The rear speakers in question (the door speakers in the rear), can turn up loud, but with twice the volume as the front's. The fronts are clear, the rear speakers sound muffled more than anything. I'll be taking it in tomorrow. If the line out to the rear speakers are damaged on the head unit, what might you say the cause could have been?
