scatterbrain
Hi,
My current set up is Infinity Kappa 6.5 inch comps in the fronts powered off a 100 watt rms per channel amp. There's a pioneer champion pro sub in the back running off 1000 watt RMS amp. I want to upgrade the fronts to Morel Maximo 6 and run 6x9 (mid bass only) off the HU for rear fill.
HU us a pioneer dvd player
I have a few options.
1. Run 6x9 (as rears) off HU with rears set to play as subs and set the HPF on the HU at 80HZ.
Will the sub (running of the RCA sub out) function as normal?
2. Run 6x9 (as rears) off HU with rears set to play as full range and use the crossover from the kappas to filter out high frequencies and set the HPF on the HU at 80hz and let the subs hadle everything lower.
3. Install something like Tang Band W69-1042 and run them as sub or full range and set the HPF on the HU at 80hz and let the subs hadle everything lower. Are the Tang band for free air use? Can the handle mid bass well?
Which option is best?
