Readjusting the Gains?
Hook it up to a meter and turn up the gains until you get a square wave with the volume all the way up on the head unit. Then turn the gain down just enough to get a sine wave again. You will get the most out of your amps that way.
not a whole lot of people I know are rollin' with an o-scope
a dmm and some basic math will work just fine
i've never tried that before, have everything flat too? i figured at full volume you'd get a clipped signal no matter what even if you dropped the gain a tad or maybe i'm wrong -shrugs-
It would only be clipped if it is a limitation of the head unit. To me it is dumb for them to allow the unit to run in that range. If it is clipping due to the amps it is because most people play with the gains and turn them up too far and when they turn it up it messes up the amps causing distortion and bad sound. Tune the levels you want on that amp and then find the point of distortion and turn it down just a little bit.
It's funny, the aveage Joe is really clueless about gains. That is one of the first things I really learned from you people here on the forum. I spent alot of time with my old set up with gains. I wanted to make sure I could turn it up worrie free, and not have distortion or clipping. The forum has been a big help in this area. It would seem alot of people out there see it as more power so they crank the gains way up and poof! Speakers blow and amps sizzle.
MBrock4u
MBrock4u
Granite City, Illinois
MBrock4u
NorthFramingham
    Jun 30, 2026
