RE XXX or RE MT
well price isnt a huge factor since these next subs will prob be the last subs i will buy until i put a blow through in the truck since i am limited in space
i will prob keep these next set of subs for a while so i want something thats gonna be loud and the loudest 12's possible for the money for the years to come
i do know something haha but i dont know much about re audio never owned them before and just hoping maybe somone has ran my current setup and switched to another set of 12's and got louder thats what i am trying to do and figuring i can triple the power to different subs they should be much louder
Get 2 12" dd z subs if money isn't a factor
Otherwise look into aq hdc's or fi bl or btl mach 5 spl ia death penalty aa havocs
there are a ton that get loud in the right box
the box you have would give each 12 roughly 2.5 cubes each which is a pretty generice optimal space for most high output 12" subs. I would think about adding another 6 in aero though cause 1 6 in port for 2 12's is not enough port area
well if its not enough port area then if i put more port area in it would it get any louder
also if i added another port it would be too long to fit in the box
my box specs are 33tallx13.5widex28 deep external
subs mounted up port back
for 2 6" aeros tuned to 33hz the ports would have to be anywhere form like 23-25 inches not eactly sure wat it said and the box is only 28 external so 26.5 internal would only give about 3 inches from the wall to the port i read that the port is 6" so it must be 6" at least from the wall of the box and objects outside of the box
Yes general rule is to keep at least 6 in clear from each side witha 6 in aero port. and yes it would get louder and sound better that is if you do it right. I just finished my box for my 2 12's and I had 1 15 and I can't wait to hear my dd's
I would take the XXX over the MX anyday of the week. To many people have mechanical issues with the MX. I have practically heard it on every video with someone running an MX on here or other sites.
And if a XXX can't get loud well sounding insanely good, then you fail at the audioz! Personally have seen 1 XXX 12 do 147dbs on an older TL in 2005 off a 2k amp and sound awesome! I would love to rock a couple XXX's or hell even one.
well either way i go will either sub be louder than my 2 l7's on 1500rms compared to say 2 xxx's or 2 mt's or dd z's on 4-5krms, even though the l7's have more cone area the other subs can handle more power
which will be louder
king ranch
Banned
king ranch
fl
king ranch
