RE XXX 15: sound quality build; ported or sealed
LOL at the second part of your sig..
So basically they used to have a more linear frequency response, but less SPL; the new ones get as low, hit harder, but are more peaky... I don't see how that makes them inferior all together, just in the linearity aspect... Depends on what you are after.
Anyways, here is some extreme excursion in a sealed box; I don't see where some people get their info (They don't have enough motor for full excursion)...
so if the old ones have a more linear freq. response, and you are looking for an SQ build, why did you go with a new XXX when the older ones willo fit your build better? (and cheaper too)
they can be hard to find sometimes, not a lot of people know about them either
On most music they won't. He was using over rated power and I'm not sure how big the box was, probably large for a single sub. Also, that song has a very loud 29hz tone. Look at the rest of the excusion vids on youtube, it's all bass I love you because of the 10hz tone. Unless you want to do a very large box, the size that could easily fit 2 "normal" subwoofers. If you don't plan on playing alot of
Also, the old XXX's def dont' have less SPL than the new ones.. In a sealed box on the lowest of notes that may be true, but again, for a normal car audio applicaton the older XXX's are going to be louder between 30-50hz. above 60 they both **** and below 30 the newer ones have the advantage overall.
If you going to do a XXX 15 sealed I'd be going around 4-5 cubes for it. Depends how much space you have really, and how big the vehicle is. 4cubes if it's on the smaller side, 5 if it's a larger sedan or SUV type.
Thanks for the imput. What experience do you have with the old and new xxx subs? And you don't think the nex XXX will be louder since it has a higher RMS rating?
I found one local for cheap. Plus the professional reviews are outstanding.
all I see you talking about is excursion. why not post vids of SQ also? Your question has been asked and answered, multiple ways, all of which will work. Get off the computer and build your box and let us know how it is.
Well, people are making questionable comments about the abilities of the sub, some say ported some say sealed, some are saying the sub's motor is too weak for full excursion which it obviously isn't....... Don't know who to believe..
IMO people on this site just have a boner for ported boxes and XBL2 or whatever subs..
Since the guy in the professional review I posted earlier asked the engineers at RE for the best SQ specifications and the answer was a sealed box 2.5 times larger than the optimal size listed on their site that's what I'm going to build; a sealed box 2.5x what is recommended on the RE site.
On top of that the guys who actually perform calcs based on the T/S parameters of the sub say everything points to a big sealed box.
I guess I was hoping to hear some testimonials from people who have ran both
I have a 2008 XXX 15". It's been sitting in storage for a year or 2. I never had much luck running it ported (5 cubic ft. @ 30hz). It was quite horrible sounding; peaky at certain frequencies and also certain frequencies were non existent. I guess the best way to explain it is the frequency plot graph would look similar to the McDonald's golden arches sign. Eventually I plugged the port on the box. Sub was firing up in the back of my Jeep Liberty. It sounded great when I wasn't moving. As soon as I started driving it was as if I had no sub.
For now I've given up on using the XXX in a vehicle. I think I'll turn it in to my H/T sub.
XXX on 400 watts sealed box on music 3" P-P excursion
Think what you want about your driver.. If you really want some honesty about it from an outside source check the data-bass reviews. This guy basically buys and has people send him super expensive drivers so that he can test them properly and see how they do.. Very measurement oriented, he has a great setup and he's no bias. As you can see, while the driver is good, everything I said about it is true. That video you linked didn't look like music either, looked alot like a test tone dropping in frequency, that's not music.
Anyway here is the review of the sub in a 4.5 cube box. Remember in a car you'll get cabin gain that will alter this response, but this is the basic starting response in an open field. "Using the XXX 18 driver in the 4.5 cube sealed test enclosure handicaps it substantially and results in a humped response shape with a significant roll off towards the top end. Sensitivity is very low due to the high moving mass and low BL^2/RE of the motor. This driver wants an enclosure many times this size for a maximally flat alignment. Additionally the huge excursion levels supported require tremendous amounts of amplifier power to make use of them. Power levels that are likely not realistic to use. Distortion performance below 50Hz is pretty good considering the output levels reached but would probably improve substantially in a larger airspace. On the positive side the chance of running out of excursion with this driver in a cabinet this small is next to nothing using any sort of typical amplification scheme. This driver is much better suited to larger sealed enclosures, giant vented alignments and probably most of all IB. "
anyway http://www.data-bass.com
Again, not a terrible driver but the car brings out this drivers weakpoints even more. The peak near 30-40hz that this driver naturally had due to the heavy coil and high inductance is right where alot of cars have alot of gain. Most cars have nulls between 60 and 80hz where this driver won't play. Your going to have probably a 20-30db difference between 80 and 40hz hz in a car. It's an expensive speaker and it can be a good one, but really this thing is built for a HT system. If your goal is 10hz at 120db's this thing can deliver, if you have the room. Check out the measurements of the ported setup they tried 30+ cubes at 12hz tuning, that's where this thing shines, stupid big boxes tuned very low. Even in a box that big, plenty of woofers can provide more output ABOVE 30hz in a box iiterally 1/6th the size, which is where most music plays. This may not be a problem for you, assuming you planned on crossing your driver over at 40-50hz. Really it depends what you wanted out of the speaker in the first place. I just know alot of people are very disappointed with these things when they get them into the car. Not because it's a bad speaker, but it's not really designed for musical playback, let alone in a vehicle, despite how RE markets them.
Between the new and old XXX the power handling is difference isn't super significant. The XXX used a fairly beefy 3inch coil, most users put 2-2.5k on it without issues. XBL^2 also makes the driver very effecient, as it doesn't lose motor force as the coil leaves the gap. That kind of effeciency you wont' see on a standard t/s sheet, it takes real world testing and measurment to see that.
Anyway back to your setup, what other speakers are going into the car, what kind of car?
mugen08
Win aplenty
mugen08
Outside the box
eradicator006
