It'll handle enough power and do it in home audio in a large bo (9-12 cubes for the 18 sealed), but your right, any box that fits in a car won't likely be effecient enough to use the xmax, especially if he's playing real music through the thing. I really would never use one of these in a car period, but if I did I still couldn't port it in good conscience.I see what you are saying, but that sub won't use that xmax in any box. And a lot of it has to do with the split coil not handling power as well as it should to even achieve those levels of excursion.
OP what kind of music do you want to bump to?
XBL^2 is a low distortion motor topology utilizing a grooved top plate to redistribute the flux field in a such a way that as the coil and motor keep a BL value that is at least 70% of it's value at rest over a longer distance than is feasible with a standard design.Engrish prease
Has this been tested? I have seen videos where the sub was obviously at 4" peak to peak excursion....that sub won't use that xmax in any box. And a lot of it has to do with the split coil not handling power as well as it should to even achieve those levels of excursion.
LOL at the second part of your sig..they aren't saying the new XXX is garbage, just not what it used to be
