Re Vs. DD
You can get good info out of Njcc, if you stroke him correctly. Judging by his replies, I think you found his G-spot.
LMAO.
That was good.
I try to help those that are willing to help themselves, if someone posts a simple honest question, I'll try to help.
Thanks they are 12's and not the 15's but that helps out alot the plan is going to be to have a box for daily and a box for comps. So I guess I do want some sq but am leaning more towards spl. ........
Last I checked, When I picked up my 3515's (paper cap) it was $350ish total.
The SX's, IIRC were around $279+ shipping to my end of NY. But that was a while ago and I'm prolly off.
If you have 2kw @ 1ohm & 8ft^3 NET to work with, I'd recommend the RE SX's.
More power & a lil less space, I'd go DD.
These are my Opinions though. On the other hand, I KNOW that there are other woofers out there that'll do well within your requirements.
Ever ponder a single 15"?
LMAO.
That was good.
Yeah I know. We've had our differences before, I still respect how you help people. Glad you took it the right way man.
yes I have but I have no clue what to go with. I would really like to use under 8 cubes but I can. I have found that the bigger boxes seem to struggle in my trunk. I had two 15 inch Koves in there and I was only hitting in the low 140's so I figured that I had just simply not given them enough outside space but the box they were in was around 12cubes interior tuned to 48hz.However that was a little over a year ago and I have believe it or not learned alot since then, so maybe I will try one of those for a whileuntil I do a little more research.I just do not want to put one ZM on that amp because I blew three or four of them off of the pole piece whan I was running two and that got old. So I got my replacements and just stuck them in the basement. If I were to consider one 15 what companys should I look at and or what other co. should I look into before I make my choice.Thanks again Bud
the SX murders the 3500 in any SPL use install... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
hell, the old SE walked all over em too.... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Loyd L.
Loyd L.
ANY?
Thanks bassman I have gotten many mixed opinions but as for right now I am just getting prices and doing research to try and find the best possible spl sub to fit my budget and my amp oh and also space . I guess I will just start taking on all suggestions and then start researching again. Thanks to all who have posted up to this point and I look forward to getting any new info.
Bud123
Bud123
Louisville, Ky.
Bud123
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
