Re-tuning a box with slot port *pic*
jesus man just re do the box bro! no money? just go fuck sum fat chix for sum $$!
re do the box with the 8" sonotube with the length at ~9.5" or so for a 35hz tuning
make sure that the tube has at least 8" behind the end of the port though bro!!
I'm just tired of buiding boxes... i've just build one for a car that i sold 1month later, now i did this one a month ago and... 100$ worth of stuff each time... that's enough !!!
I'll probably be switching sub again in few months anyway //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
8 inch of clearance? that's gonna be difficult. Is it really THAT important?
Yeah the box is on the low side, but the last one i had was too , yet still sounding a lot better to me... Like i said, box is 7.2 after sub displacement. The port atm 17height 6.75 wide.
From my calculs, that gives 114.75 then divide by 7.3 ( or is it after port displacement???) = on the 16ish per ft/cu... my last one was more like 12-13 , yet sounding a lot sharp and better transitient response on fast kick bass
also the idea of trowing mdf in it... how do i do that? cut smaller and silicone ? i'm not sure this would be easy
well if it's 7.2 cuft before port displacement then with port displacement @ 37hz that only gives you roughly 5 cuft for both subs to share.....you could always build a square port like this....(i'm in the same dilemma sorta...probably gonna go 8" sonotube or square port like pictured cuz the slot port takes up too much volume)
oops here's the pic i was talkin about....
you can use mbrooky idea, and do a removable port like i did.(sub up-port back) that way you dont need to re do a box. just play with dif. port lenghts and diameters.just try to do long port so you can cut to yor fs needs.
So i did some mods to my box yesturday and had few listening hours already.
Sub up , 8inch sonotube up... around 6 inch of clearance before the window.
Result: -On some songs, the bass def hit harder than with the port on rear side.
-Tuned around 37hz killed some lowest line (34hz before), but the upper roll
seems higher. Still some hard flexing lows. I guess its from getting some more
airspace. The 8inch sono take very little compared to the port i had (i destroyed it
with an hammer and sealed the port hole.
And finaly, i'm getting some port noise on some tracks i didn't before (white girl).. a little annoying. I put the ssf from 15hz to low 20ish and it help a little
Definitively more rearview mirror movement now too...
So i think the operation went well. On a bad note, I destroyed most of the bracing by destroying the port. The box is flexing a little, but no air leak.Sounding better to me.
Any bracing i could add one the box is sealed? And i'm looking at 10inch sono... but i don't want the bass to be too boomy
Great. Aeros are great for that too. If i'm not fully satisfied with the tuning. just put another lenght or cut and you got a new box //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
That box already went through 3 operations and still alive
any pictures on the new box??
You could add threaded rod or wooden dowels to the inside to stiffen it up. To add flare to the sano tube you have to make a piece of mdf that is flared then add it to the end of the sano tube.
Getting the bracing inside, once the box has every side on ain't easy... i have no skill and no equipment beside a jigsaw... any pics or dyi of the process of turning a sono into a flare sono
Xprime4
****in' canadian
Xprime4
Quebec, Canada
Xprime4
