RE SX or SE power problem
DaGh0st
Drill Baby Drill!!
ok i have the Hifonics 1505d if i get the two se's ill be able to run it at 1ohm but if i get the 2 SX's ill only run it at 2ohms witch is only 1000w diveded by the 2 subs.(the amp really only put out about 800w) Witch should get louder in a ported box the 2 se's with full power or 2 sx's with half power? with both boxs to spec
the se's should be louder. with 250rms more per sub or a 1/3 more, and should sound better doing it.
No I believe you are wrong. The SEs are SQ woofers so getting a high score out of them would be tough. Just going with the one SX would be the best bet, even though you wouldnt be giving it the needed wattage.
Too bad you have that Hifonics amp. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
original poster...please dont listen to him as he is 100% incorrect
1 SX is with 1400 RMS will be louder than 2 SE's with 1400
I have had both setups...
2 SX's would have to be wired at 4 ohms for that amp and would be worthless.
Get one SX, be loud, love it
and as it turns out, I have one for sale...read my thread in my sig //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
To help a fellow "ghost" out....
2 SE's ported will get loud and have cleaner lowend and would sound better then 2 SX's at that power.
The other option would be to get 1 SX ported, if you move to a larger size sub, that could put up a higher score depending on teh install.
DaGh0st
Drill Baby Drill!!
DaGh0st
Caro,MI
gHOstFaCe
michigan born
    May 14, 2026
michigan born
    May 14, 2026
