Sold RE SX 10" D2 $150 shipped obo!
Suicide Bobb
SPLC Fails
PRICE DROP - $120+SHIPPING FIRM
This sub is in very good condition (9/10). Comes in original box. This one is the one made under U.S. Amps ownership, so it may not be as good as the original, but it's still one helluva sub for the money. The most power it has seen is about 600wrms from a Directed D600.
Geoff had owned the sub at one point in time, then he sold it to our buddy, who sold it to me (he needed cash fast). I can take a video of it bumpin if you need that much verification. Don't let me lack of itrader discourage you, I have done many more deals than it suggests. Ebay - kvansloten, Caco - ******* bobb (again, more deals were done there than are shown), and some more I can't think of right now.
Let me know if you are looking for anything else as well, I have a couple electronic crossovers, amps, and a sub. It would probably be most efficient to do a package deal, and of course I'll give you a price cut (probably a big one) if you buy more than one item. The shop is about to finish fixing my car, so I need the money before then.
I do an excellent job packaging btw, and can package the original box in another box if you would like (or wrap it is something to keep it from getting scratched). I usually don't like to ship things because I am OCD, and literally will spend at minimum an hour packaging my items.
RE AUDIO was founded by audio enthusiasts, for audio enthusiasts. They understand the uses (and often abuses) in autosound and engineer products for use in the real world. RE Audio products have the finesse and sound quality to please the most discriminating audiophile, and the durability to stand up to the extreme abuses of SPL competition. RE Audio is taking the car audio competition scene by storm. Join the ranks of the competitors with RE Audio.
RE Audio: "Built for Brutality, Engineered for Excess"
The RE Audio SX Series is the epitome of what a daily driving subwoofer should be. This sub has excellent sound quality and extreme output.
SX10-D2 (SX.10.D2/SX10D2) Features:
* Dual Composite 2-piece Cone
* Rubbertek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3 ” 8-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Magnets
* Progressive Spiders
* Wrap around Rubber Gasket
SX10-D2 (SX.10.D2/SX10D2) Dimensions:
* SX10 10" Dual 2ohm Subwoofer
* Mounting Depth - 6”
* Mounting Hole Diameter - 9.25”
* Overall Diameter - 11”
* Bolt Hole Circle - 10.125”
* Motor Width - 6.5”
* Motor Depth - 3.25”
* Basket Depth - 2.75”
* Displacement - 0.15 cu. ft.
* Weight - 23 lbs.
SX10-D2 (SX.10.D2/SX10D2) T/S Parameters:
* Electrical Q Value -Qes: 0.29
* Mechanical Q Value -Qms: 4.3
* Total Speaker Q Value -Qts: 0.27
* Free Air Resonance -Fs: 30.7 Hz
* Equivalent Compliance -Vas: 21.8 liters
* One-Way, Linear Excursion -Xmax: 22 mm
* Efficiency -SPL 1W/1m: 85.2 dB SPL
* Effective Piston Area -Sd: 310 cm^2
* DC Resistance -Re: 1.9 ohm
* Nominal Impedance -Znom: Dual 2 ohm
* Thermal Power Handling -Pe: 1000 W
* Force Factor -Bl: 21
SX10-D2 (SX.10.D2/SX10D2) Recommended Enclosures:
* Ported Compact: 1.0cf tuned @ 35Hz
* Ported Optimal: 1.25cf tuned @ 34Hz
RE Audio SX Series SX10-D2 10" Dual 2ohm Subwoofer ShipSound.com
Pics up!
Dropping the condition down to 8.5/10. It has a couple of very small scuffs on the surround. They are more like rubs. None are more than skin deep. Still keeping the price where it's at, it's too cheap already.
Suicide Bobb
SPLC Fails
Suicide Bobb
Camas, Washington
Suicide Bobb
