RE SE / Kicker CVX sealed??
biggen_bd
Basically I have a sealed box with .86 cu. ft. before displacement per chamber. Basically trying to figure out which sub will be louder in this type of box 2 12" RE SE's OR 2 12" Kicker CVX's
The amplifier being used is a Memphis MCD1500 --> 1500watts @ 2 ohms
OR
MTX 1501D --> 1500 watts @ 1 ohm
I have both amps just really wanting the loudest application with 2 12" subs that will work in the .86 cu. ft. per sub space. (must be sealed have no other choice)
(reason for sub choices is mounting depth I have around 7 ~ 8 inches of mounting depth before hitting bottom of box)
Any help would help A LOT!!
-B
Really? Thats crazy if so, be sweet...
Very nice..
Also, would you say go with the 12" SE's over the 10" SE's? The only reason for this would be the 10's would have that tiny bit more air space to help them breath in the sealed enclosure or is this not going to make too much of a difference?
-B
biggen_bd
biggen_bd
Missouri
biggen_bd
