sjobas 10+ year member CarAudio.com Elite 536 0 sweden Sep 3, 2008 #1 or what is the lowest watts you should put on a mt12? is a aq2200d enough? Click to read more...
JL Audio 5,000+ posts ThugStep 13,839 59 KY Sep 3, 2008 #2 i ran one on a 1500d when i owned both a long while back, pounded fine but could have taken more i'm sure.
orangecounty1 10+ year member CarAudio.com Veteran 4,145 4 Tampa, FL Sep 3, 2008 #3 itll work with less power for sure, but they come alive when you give them 2k+. 2200w should be plenty though for daily...why, is it not loud? what are the box specs/how is it wired (what ohm load) etc
3 350zspl 10+ year member CarAudio.com Veteran 4,241 11 WPB Florida Sep 3, 2008 #4 i was using an mt 12 " for 3 months i used a rf t40001 bd at 1 ohm 1st , then a hifonics maxximus i would say that 2000 rms to 2500 rms would be the least i would run
audioholic 5,000+ posts not a moderator 24,425 775 Parts Unknown Sep 3, 2008 #5 or what is the lowest watts you should put on a mt12? is a aq2200d enough? Click to expand... You are not being clear at all. Your title indicates your sub died, but the post is asking what the minimum power you can run on an MT is.
OP sjobas 10+ year member CarAudio.com Elite 536 0 sweden Sep 3, 2008 Thread Starter #7 You are not being clear at all. Your title indicates your sub died, but the post is asking what the minimum power you can run on an MT is. Click to expand... sry, my question was what the minimum power the mt should have to work fine
P pawn man 10+ year member CarAudio.com Elite 1,910 0 albany ga. Sep 3, 2008 #8 it will not hurt the sub to run a smaller amp unless you clip the hell out of the amp. i have run 8k on my mt15" for spl burps & also played music with 8k. playing music have to be careful with that much power but she will take alot of power.
