Re-grounding an amp
Mike437
So after much discussing i need to re-wire my amp. right now it is grounded in the trunk using a spider screw/nut but is just touching the paint. I need to remove this and then scrape the trunk bed to expose bare metal. Do i need to disconnect the negative on my battery under the hood if i want to do this? I mean i just want to be safe when i do this, mind you i did not install my amp but the guy who did, did not ground the amp properly. So before i disconnect the ground on my amp, should i disconnect the ground on my bat? or anything else i need to disconnect?
x2 pull your inline fuse out, reground, put inline fuse back in.
recheck.
sounds good, thank you guys for your help. Will post new pics once i get everything squared away: speaker wire, power wires tied back in the trunk/hood, re-ground everything, and possibly new optima battery to make the type-r's and my hyundai more happy lol.
Mike437
Mike437
Pittsburgh, PA
Mike437
