RE enclosure calculator
When the program lays out your measurements for cut, what is the cut angle for?I assume that it's the angle that you cut the side of the front board (angled side) so it can be flush with top and bottom?
its basically telling you to make sure all your cuts are square=90 degrees. (if your box does not have any fancy angles, if it does then it should tell what angle it is)
Also, remember that the RE calc DOES NOT take sub displacement into account when figuring space and tuning so you will have to tune it to the NET displacement and add the space that the sub displaces after you design the rest
Nut Hair Trick
Pubes
Nut Hair Trick
Arlington, Tn
Nut Hair Trick
