RE AUDIO SEX12D4 any good?
mysilver02alty
This company is local to me...........are these subs worth 180 a piece? How much power would you throw their way - 2 of them, ported? Was considering these and a pair of RF T1's to go with either a sundown 1500, JL 1000 or some Hifonics 1200 watt amp, not sure
Car Audio wholesale distributor Alpine Pioneer HID Lights Clarion Hifonics Kenwood Boss - Ikesound.com - RE AUDIO SEX12D4
* Dual 4 ohm Voice Coils
* 1200 watts peak output
* 12" competition grade subwoofer
* 600 watts pure RMS
* Engineered with new magnet covers that aid in cooling the voice coils while protecting the magnet
* Flat wound voice coils
* Qes: .49
* Qms: 4.5
* Qts: .44
* Free Air Resonance -Fs: 25.1 Hz
* Vas: 72.9 liters
* Overall Diameter - 12.5"
* Bolt Hole Circle - 11.75"
* Motor Width - 6.25"
* Motor Depth - 3.25"
* Basket Depth - 3.25"
* Displacement - .15 cu. ft.
* Weight - 22 lbs.
* One-Way, Linear Excursion -Xmax: 18 mm
* Efficiency - 86.1 dB SPL @ 1w/m
* DC Resistance -Re: 2.8 ohm
* Mounting Depth - 6.5"
* Mounting Hole Diameter - 11"
* Dual Composite 2-piece Cone
* Rubatek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3" 4-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Maganets
* Progressive Spiders
* Wrap around Rubber Gasket
I had a pair of RE re's.............These arent gonna sound like them i hope //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Cuz they sounded weak. Had to take them out after like 2 songs and sell them.
I had four of the older SE 12"s at one point, man. They sound good, handle a decent amount of power and are somewhat loud. I wouldn't call them weak. A pair on 1,200 - 1,500 watts will do you right...
I have four RE's and they kill in my car... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Maybe you were doing it wrong.
I don't know, they were the lower line re's, like 250 watts each i think. but yea, more than likely i was doing it wrong //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
They're 175W each, but I throw about 250 at mine daily and just check the temps on them after beating hard.
My box is tuned low like yours and it's just ridiculous. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dealercostcaraudio has them (the SE not the ***) for $150 new. I know this because i was choosing between that, an RSDC, and a Polk SR, which i eventually went with because i found it on sale.
WinISD has it liking a box just over 3 cubes, so it would do good in that box i'm guessing. Has a relatively low resonant frequency for a 12 so i'd want to tune it low... but i've never built a box before, and 33Hz seems to be a consensus middle ground Fb
get it!
get it!
This. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
mysilver02alty
mysilver02alty
Florida
Papermaker85
